Morphius
DSM Wiseman
- 1,895
- 65
- Jun 9, 2003
M-Town,
Michigan
I just got my car running again after fighting issues with the fuel pump.
It's sitting there idling and something under the hood starts letting the magic smoke out. From the front of the engine. Quick glance, it's not accessory belts. There was no AC belt on, and the pwr strg and alt. belt are fine. My guess is the balance shaft bearing went bad and burned the balance shaft belt up.
Any issues with just taking the belt off and leaving the balance shaft in? Or do I have to install a balance shaft eliminator kit, which is essentially a "plug". It's cold out and I really don't want to play around with removeing the balance shaft, or installing a new balance shaft belt. If it is bad,I'd just rip it out. The main belt should be OK as there is only 30K on it.
