eclipse_20g
- 251
- 6
- Oct 24, 2003
Mercersburg,
Pennsylvania
Here is the deal. This 1g I am looking at has definite tranny problems. The only problem is, I cant find one other thread anywhere with anybody that has this problem. So here goes the symptoms:
Tranny does fine while cold.
Clutch is the softest/worst I have ever felt. Almost completely release pedal from floor until you start moving.
Once the tranny is warm, this horrible grinding sound comes from the tranny/t case/center diff/viscous???
In first just slowing moving along, the noise is not there. I didnt get on it after I heard the sound due to being scared for my own life
However, second and third make the noise horribly at all times and it throws itself out of gear. I didnt not try anything in 4th or 5th. I'm sure that 1st would make the noise too given the throttle. I know this sounds like the other posts, with the sound not being made when clutch pedal is depressed, but nobody else ever says anything about being thrown out of gear. This happens at all speeds. Any answers will be appreciated. Thanks
someone lend me 600$
. Most shops want 250-400 for labor.
