auto trans????
4g63swap
258
Aug 9, 2003
I need to know what parts I need to connect the engine to the trans for an auto trans. I have an idea but not sure. flywheel, torque converter
what else or am I wrong? oh and how mush hp will a stock auto trans hold?
thanks
4g63swap
A cupple of things 1 a 90 to 91 nt flexplate ( It has a spacer behind that can be removed for about 3 mm of space) The factory Tq has to be modded to accept the 3 eared flex plate (factory has 4 ears). The bushing on the back of the crank has to be swaped from the 7 bolt to the 6 bolt ( the 6 bolt's is not drilled all the way threw as the 7 bolt's is).
From there the rest of the swap is the same as any 6 bolt.. :talon:
Pic of the modded 2g tq
