tranny doesn't want to go into gear
kandt
151
Mar 27, 2002
lately i have been having some weird problems with my tranny, it doesn't want to go into any gear, like if i'm at a stop light and try to put it into first it will go in a little bit but not all the way, now it does it in all gears , you have to like push the shifter hard and like wiggle it around to get it into gear. so what do you guys think because i'm pulling out my tranny out this week and i'm wondering if i should or not.
thanks
well b4 taking it out, try changing the tranni fluid it does wonders, if it still giving u a hard time could be worn synchros...
I know what you mean my troubles like this started today going up the express way all gears crunch i think ive got a bent fork of somthing badly loose because somtimes its good then next time its bad i have to double shuffle every gear.
Guess what pulled whole gearbox down no troubles then removed bell housing and found one r.s clutch totally stuffed.what do you sugest i get for a 16g flywheel or not .
