RaysTsi
- 323
- Nov 4, 2002
Charlotte,
North Carolina
Ive got a 2g AWD and i just put in a 6 bolt head/block and an ACT 2600 w/street disc. If the car is on you cant get it into gear and theres a loud grinding noise. if you put it in gear with the car off and then try to start the car it will rock back and forth. Should I bleed the clutch again? Ive checked both master and slave cyclinders and they both look good. I installed a new throwout bearing also.
