SpoolinGSX
- 84
- 1
- Nov 4, 2002
Bay Area,
California
I pulled my tranny for a clutch/flywheel replacement. The problem is that i cant get the tranny back in. I have my car on jackstands in my driveway and am using a floor jack with a transmission adapter. I can get the bell housing over the pressure plate but if you are looking in from the passenger wheel the left side will not slide forward on the the dowel. I can only get the right side pretty close. I have the shifter in nuetral, and i put it in gear and turned the crank and watched the splines move inside the axle housings, so i know that the input shaft is lining up right with the friction disk. It is so frusterating, i have been working for over 12 hours to try and get this back in with no sucess. I have a track day on wednesday i would really like to get to. Any ideas?
