DSMRevolution
- 1,629
- 11
- Dec 6, 2002
Sioux Falls,
South Dakota
Because I will be pulling the engine, I want to replace the engine mounts (not motor mounts
). I was reading GVTalon's how-to article and it got me thinking. I was going to still push the plastic cutting board stuff into the mounts, only I was going to fill them different. I am going to fill them with polyurathane from Home Depot. It should be about the same.
Now will adding the board pieces alone make the mounts as stiff as inserts or so? How stiff do you think it will be when I am finished? Would this mod compare to aftermarket engine mounts? In his review, I didn't really see how they compare to aftermarket.
Thanks!
). I was reading GVTalon's how-to article and it got me thinking. I was going to still push the plastic cutting board stuff into the mounts, only I was going to fill them different. I am going to fill them with polyurathane from Home Depot. It should be about the same.Now will adding the board pieces alone make the mounts as stiff as inserts or so? How stiff do you think it will be when I am finished? Would this mod compare to aftermarket engine mounts? In his review, I didn't really see how they compare to aftermarket.
Thanks!
