Driveshaft thump with new carrier bearings?
Ryan H
70
Nov 19, 2002
I recently replaced the carrier bearings and u-joints and just yesterday while logging the car I decided to launch the car and for the first time ever the driveshaft smacked the bottom of the car and the exhaust. I did another launch to make sure it wasn't the way I had launhced the car and boom, it did it again. Now just some history here, over a year ago I filled the old carrier bearings with silicone thinking that would help stop that driveline noise, ya know the whum, whum, whum when on the decel, ya well I was obviously wrong. Having done that I never did have a problem with the thump once the car was modded more. The thing is now with brand new carrier bearings I shouldn't be getting this thumping on the launch. I'll end up filling these ones with silicone, but why would new bearings do this?
Fill the carrier bearings with 3M Window Weld®. I found the shit at a local autobody paint supply shop. Just call around. It's supposed to be for repairing the seal on your windshield. It's liquid and when cured it hardens into a hard polyurethane. You probably have too much horsepower for the stock bearings. What turbo do you have? Is your car full-weight, you might want to put it on a diet.
yes i marked everything and put it back the way it was before. It must be balanced cause there is no vibration at all. I asked my friend who has more power than me, about 400whp+ and he has never had this problem and his bearings are untouched, no silicone, nothing.
As for power I'm running an 18g @ 20psi, about 300whp now, maybe a bit more.
I have no problem filling them again with silicone, but what gets me is that one my friend with more power and original bearings doesn;t have this problem and 2 the bearings are brand friggin new?? I'm just surprised.
I went to go pull the driveshaft off to fill the bearings with silicone, but I noticed that the rubber bushings that hold the bearings onto the car were not installed right, so I reversed them and that tighten things up since there was too much play before. So I took it for a test drive, lauched it 3 times and the thump is minimal now, just a little smack smack thats barely noticeable, but still not good enough for me so I'm filling them with silicone.
Maybe check your motor mounts, too. If the engine rocks back too far under power that could put the first U-joint at a hard angle.
I just filled the front and driver side mounts with urethane, they're rock hard.
