Overdrive Light NOT ON!!??
Stingray90
35
Mar 26, 2003
Does the overdrive ON/OFF light display with the key in the ignition position ( not running)?
I ask because I have a 1990 n/t talon automatic I'm converting to a turbo using a '91 FWD turbo: tranny, TCU, and the different sensor connectors needed. This was a JOB and a half for anyone doing the same. Anyway, with all the work Im doing, I've had the car sitting w/out a battery for months. Well today, I finished all the electrical work needed for the conversion. So I put the battery back in and put the key in the ignition position ( cant crank it yet) and I see that POW/ECO illuminates and switches back and forth as it should when pressed, but the O/D doesn't light AT ALL.:confused: Just wondering if this is normal. Thanx!:talon:
