2nd Gear is grinding
Wishingforagsx
55
Jun 19, 2003
Taylorsville,
The 95 Talon TSi i am buying is grinding 2nd gear. the guy took it to the shop and had the syncro replaced, but it still grinds. Any clues other than replacing the tranny, that is a last resort
Welcome to the world of DSM's!
no, but seriously, there are a few things you can do to help, although I m not sure if they ll work considering you said he already replaced the synchro... first make sure you ve got good fluid in it, then, make sure that the cables at the shifter are adjusted properly, and third, bleed the clutch, and readjust the pedal, there s info about doing it on TRE's website.
  • Wanted 1g Wanted - 91-94 1g Throttle Body or replacement shaft + plate
    Looking to replace a TB with a complete 91-94 or replace TB shaft + plate. Let me know!
    • athlete3344
  • For sale 1g 90 Oil Cooler
