1g tranny to 2g
so i can use a 1g tranny in a 2g, i dont want to get flamed but has any one done this before 2g trannys are kind of hard to find now and days.
Certain years of 1g trans are preferable over a 2g trans.
I didnt start this thread, but it has interested me... MNGSX, you said certain years of 1G trannys where prefered over the 2Gs. Do you know which years and why? Also, are we talking about a 5 speed or an automatic? I am needing a 5 speed for my 2G and if I can find a better tranny than the 2G tranny then Im all for it. Thanks-
Galant VR4's have taller first gears than other AWD trans.
The 3&4th gears on the intermediate shaft are stronger on pre 93.5 trans.
If I were you I'd get the TRE AWD converted to FWD. Strong!
no one even mentioned the difference in spline counts.
22 spline to 23 spline.
I have a 23 spline 1g going in my car. Its fine. You will need to do little things like swap the speedo sensor and things like that.
What about the mounts, 2gs have a mount on the back of the tranny and 1gs dont. Correct me if iam wrong but has andybody have a 1g tranny in a 2g right now and working?
please someone tell me that i can do a 1g fwd turbo tranny into my 2g gst easily! I can get 1g trannys all day long but 2g are like a herd of flying unicorns.
Hey cheif be the guinea pig.
Or just look at your 2g trans and then look at a 1g trans.
Better yet take pics of a 1g trans where your 2g trans has mounts bolted to it and post it here.
I think it will go.
If anything you'll need a little fabricationg for the one 2g mount that the 1g's don't have!
1g motors fit 2g bellhousings and vice versa!
So the question can you find a way to get 2g trans mounts on a 1g trans?
:talon: So YES i can use a 1g awd transmission on my 95 awd tsi talon? and if this is true is there certian years i should look for?
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
  • For sale 1g 1G Turbo Intake Kit
    Used 1G turbo intake kit. Fits on stock intercooler and uses stock BOV. Comes with the MAF and...
    • Badge023
  • For sale 4G63 Used FP 4G63 Turbo Manifold
    Used FP 4G63 Turbo Manifold removed from 1G Talon. Looks okay, needs a cleaning. Did not see any...
    • Badge023
  • For sale 2g Fiberglass Fenders
    2g Fiberglass fenders. Overall good condition. $50 + Shipping/FeesFor faster response Text...
    • 1SlowPOSEclipse
  • For sale 2g 97-99 Mpi relay
    2g. 97-99 Mpi relay. Many don’t realize the later 2g doesn’t use the same mpi as the 90-96...
