twoboosted
- 178
- Nov 20, 2002
south,
North Carolina
I have a 90 gst and installed an rps clutch,fidenza flywheel step set at .610 and new master plus slave and the freaking still will not go into gear. Bleed the clutch no air and still no gear.
My question is the clutch under the dash rides on a spring/rod and when you push the pedal down a little it slips of this rod. the pedal aft puxhing it to the floor does not come all the way back up. could this be the problem and if so where the hell do I this rod? also could I use one from a 1.8nt?
