Akiori
- Mar 11, 2003
Asia
does spline reflect its gear ratio also ?
or are they 2 different things?
Q-1>Will a 1G 23 spline transfer case bolt on my 97gsx?
Q-2>do they have the same transfer case gear ratios?
Q-sum>If I get a 23spline transfer case from a 1G, it will bolt right up
and the gear ratio will be the same ?
this is so confusing.
check what I found using the infamous search button.
"92~99year 23spline transfercase are interchangable"
"98+year models changed all their gear ratios"
"97+year models had their gear ratios changed"
"you can use same spline transfercase for 1g's and
23spline x-case for 2g's, but same spline 1g/2g x-case isnt compatible "
"1g and 2g xfer's bolt patterns are probably different"
use the search button they say
and this is what I get. sigh*
help me out..
THX.
help me out..
THX.
