Car grinds going into 1st
quick_silver90
Jan 24, 2003
Hi,
I need help here,
I reciently bougt a 91 AWD Talon and I have problems grinding going into first.
Wheater I am at a dead stop or try really slow this car likes to grind big time going into first.
But its funney once I am into first the rest or gears shift fine and know grinding.
Know I just had the clutch fluid changed to sycro.. and we had a few dsmers try to adjust the clutch peddel which helped alittle but it still grinds into first.
Know is this a problem with the cluth or the tranney?
Thank You,
Shane
Just a quick grammar lesson, please don't take offense as I see your not from the U.S
know- to understand/comprehend something
now- is a statement defining the current time/present tense
no- Ill just give an example
you should have said "no" here instead of "know" :thumb:
If all other gears are fine except 1st and the clutch is adjusted properly, no leaks, correct pedal height...etc then you can assume its your tranny. Really the only way to get it done is to take it apart;) I would recommend you also replace andything that looks like its needs replacing, all seals/bolts/bearings/pins, and if you have the money you might as well upgrade a little bit to...
  • For sale 1g 90 Oil Cooler
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
