captconnels
- 151
- Aug 19, 2002
sunday 4/13 i was out cruising with a couple buddys, one challenged me off a light so i hit it. my clutch was on the way out i planned on changing it soon anyways. pulled like a bi*** through 1st. but felt like i missed 2nd. then i realized the clutch pedal was stuck to the floor. got to my buddys place a half mile down the rd and trailered it to a garage the next day. just thought i blew apart a clutch. we got it torn apart down to the tranny, then i started finding little metal shavings
and chunks of aluminum, at that point i knew i was ####ed. i found 2 holes, one on the top about a half inch wide and 3 inches long. and the other on the bottom the size of a quarter. both holes are on the housing that covers the clutch assembly/flywheel so i hope i can get away with just replacing the housing but i doubt it.
i had had some symptoms of crankwalk throughout the winter like sticky clutch pedal etc. im thinking that coulda been what caused it. the track last week loosened it up enough so that the crank walked too much pushing the flywheel into the clutch assembly and sent something throught the top of the tranny. thats just a thought.
im looking at an Evo 6 motor and tranny. might be time anyways. gimme you thoughts/opinions on what happened, or what i should do or how much im lookin at to fix this beotch
and chunks of aluminum, at that point i knew i was ####ed. i found 2 holes, one on the top about a half inch wide and 3 inches long. and the other on the bottom the size of a quarter. both holes are on the housing that covers the clutch assembly/flywheel so i hope i can get away with just replacing the housing but i doubt it. i had had some symptoms of crankwalk throughout the winter like sticky clutch pedal etc. im thinking that coulda been what caused it. the track last week loosened it up enough so that the crank walked too much pushing the flywheel into the clutch assembly and sent something throught the top of the tranny. thats just a thought.
