blackgsxrcst
- 31
- Jan 9, 2003
the tranny shifts fine, i drained the fluid to check for metal bits and nothing.
heres the deal:
i will let out the clutch in first and right as the clutch has pretty much fully engauged, it makes a little vibration noise until i get the momentum of the car going.
then, i will drive easy in first gear, no boost, its fine. i accelerate and it begins to grind/vibrate.
this happens in every gear. i have replaced the center diff recently as well as the viscous coupler. it now has a welded center diff, and a VCE eliminator on it.
what do you guys think is going on here? i want to say its something thats loose, but im not sure. maybe a loose flywheel or loose gears. what are the chances of it being the front differential? thanks for the help.
heres the deal:
