4ged4G63
- 421
- 4
- Sep 6, 2002
Arizona
I know, another clutch adjustment/clutch fork/pivot ball/to shim or not to shim thread.
Some info. Rebuilt trans by sheptrans, installed and third gear was difficult to egage/disengage, first gear slightly notchy so I started going through the old system to rebuild it.
Pretty much have rebuilt the entire hydraulic clutch ststem. New act 2600/street disk and act flywheel, new oem master and slave cylinders, new oem pivot ball, new comp clutch forged fork, new oem t-bearing and clip.
My pedal returns to normal position, when I grab the pedal and pull up on it there is no slop, it's solid.
My new slave cylinder has a gold/yellow cylinder inside. I have heard of the red and green but never gold.
After putting everything back together the clutch engaged right off the floor.
So I pulled trans and added a shim/washer. Now in first gear I get the drag, car moves forward slightly in first gear at around 5500 rpm. So bled the system and now it doesnt move forward during rev test but still engages right off the floor.
What am I doing wrong? I'm pulling the trans and removing the shim or at least finding a thinner washer. This is ridickulous. People insist to not shim but then others do and feel their problem has been solved.
With all new parts I shouldn't need a shim.
Sorry for the long post.
