Bleeder screw size on slave? FAST HELP PLZ
Spidey
1,420
11
Sep 22, 2002
Charlotte, North Carolina
Does anyone know the thread size for the bleeder screw on the slave? Nobody is around to help me bleed my clutch and I'm about to go get a brake bleeder, but I need the thread size.
Thanks,
Spidey
Get under the car, put a tube on the nipple, put the other end of the tube in a jar with some brake fluid in it. Crack the bleeder and push in on the clutch pushrod, close the bleeder and let the spring in the slave push the pushrod (and piston) back out. Repeat twice, check the fluid level in the master.
2nd choice: hook up the bleeder tube, crack the bleeder, get a turkey baster bulb and put it in the clutch resevoir and squeeze, forcing fluid through the system and out.
Since the entire system is down stream, bleed it with gravity. Open the bleeder and let it run until there is no more air.
Welp, SS braided clutch line is in and bled, everything is fine and dandy now, pedal is way stiffer than before. For future reference, the thread is 10mm, you'll need the 10x1.0 speed bleeder.
-Spidey
