awdsman
- 1
- Feb 2, 2003
I am dropin the tranny my self in my 95 tsi awd...I just have on problem right now. On vfaq it says "Disconnect the speedometer cable and reverse light switch connector from the transaxle. The reverse light switch connector simply unclips, but the speedometer cable is back by the rear motor mount, and that is a pain to get out. You have to unscrew a 10 mm bolt which is difficult to get to, and then you have to pull the cable out." how do I get the speedometer cable off? what 10mm bolt is it?
