Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Drivetrain Tech
Drivetrain Tech Transmission, clutch, flywheel, driveshaft, gears, differentials, transfer case, shifter, etc.
Reply
LinkBack Thread Tools
Old 06-23-2002, 07:45 AM   #1 (permalink)
Proven Member
Region: Southeast
Classifieds Rating: (0)
Reputation: 96TalonAWD is an unknown
crazy tranny problem
hi
i was just driving on 1 gear goin around to park my car when of sudden i hear a cluck and the stick when from 1 gear to neutral i thought mayve i did it but noo!! it happen some times specially when i am cornering on 1 gear and when i release the cluth it happens.
what can that be???
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 06-26-2002, 09:27 PM   #2 (permalink)
Proven Member
Region: Midwest
Reputation: GalantVR41062 is an unknown
You might want to check the shifter cables, they maybe lose or binding. The other thing that I can think of is to check the detent's, make sure they are tightend all the way down, if they arn't that would explain why it can pop out of gear. If you aren't fimilar with the tranny you can see the detents in the second picture down here: http://www.twingles.com/ideck/rebuild3/dretranny.htm They are the three bolts in a row just below the revers light switch.
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.09868193 seconds (64.08% PHP - 35.92% MySQL) with 9 queries
