Various front suspension woes- looking for tips
gijoe985
562
20
Dec 13, 2007
Grandview, Washington
I seem to run into a couple of problems. some of them routinely. Any tips would be nice.
First, trying to take front cv joints out and the spindle is rusted stuck in the hub, tried using a puller, did nothing other than almost kill me... Eventually I tried banging on it with a hammer, while it moved a little, it deformed the spindle more than everything. Finally I just found away around it, I was doing a clutch and I removed the driver cv from the tranny, but not the hub, and then the passenger I got out of the hub, but not the tranny...
2nd, what to do with all those stupid suspension joints that you need to separate with a fork... It seems 1/3 of the bolts I remove on those just end up spinning in place. I'm even using an impact gun. I end up messing up all the rubber and grease because I have to hold the other end with channel locks...
3rd, man oh man... Don't know how I did it, this is a new one for me, but I got a lug popped out, while the tire was being put on. So it is just spinning in place, the bolt already half way on, and no matter how hard I pull on it, it won't seat... That one got cut off...
Two final questions, has anyone found any tricks for these? The spindle wasn't that big of a deal, but next time, if I can't just go around it, I'lll need a better line of attack.
Second, what to the dealers/shops do when they hit these problems. If the book says 8 hours for a clutch, but my car has bolts so rusted that they are forced to take extreme measures, do they charge more? I don't really go to shops so I don't know.
With your CV being stuck in the spindle, your more than likely gonna have to take your whole hub assembly off and pound the shit out of it at to not damage anything else.
2nd- with the joints just keep twisting they will go on or once again to might have to buy a new one.
3rd- with the lug stud poping out your just gonna hve to break it off and put on a new stud. PS if you didnt work on the car last wether your putting on or taking off the lug its not your fault.
tricks- if you just take the whole hub assembly of the car its a lot easier to declutter and get things out.
  • For sale 1g 90 Oil Cooler
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
