Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Drivetrain Tech
Drivetrain Tech Transmission, clutch, flywheel, driveshaft, gears, differentials, transfer case, shifter, etc.
Reply
LinkBack Thread Tools
Old 07-25-2008, 07:14 PM   #1 (permalink)
Proven Member
MidShipCivic's Avatar
Region: Southeast
Classifieds Rating: (0)
Reputation: MidShipCivic is an unknown
1G-specific Shifting all screwed up can't go into 1st or R.
I just rebuilt a motor for a 92 talon that was given to me and started it today for the first time ever and I don't know whats up with the shifter mechanisms.
I can't put it into 1st or Reverse the 1st position I can't even push forward in and when I attempt R it's actually 4th gear?
I did something wrong somewhere.
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 07-25-2008, 09:58 PM   #2 (permalink)
Proven Member
jking29's Avatar
Region: Midwest
Classifieds Rating: (9)
Reputation: jking29 is pretty helpful and trustworthy
Try adjusting your shift cables first. Shifter Adjustment
Offline
Old 08-29-2008, 07:58 PM   #3 (permalink)
Proven Member
Region: Tri State
Classifieds Rating: (3)
Reputation: BoostedTT91 is an unknown
most likely ## cable needs adjusted. its probably not lifting the lever enough to get into gear
Offline
Old 08-29-2008, 09:53 PM   #4 (permalink)
DSM Wiseman
twicks69's Avatar
Timeslip: 9.961 @ 143.330
Region: Midwest
It sounds like something is blocking the entire movement of the shift linkage in the engine bay; I would try to manually shift it into gears by disconnecting the shift cables from the transmission and go through the gears (be sure the vehicle is off).
More than likely you have a wire, hose, etc. blocking the complete movement of your shifter linkage on the transmission.
Otherwise, you have either a damaged shift cable, or a seized shift bracket pivot point or worn out plastic shift pad on the shift linkage bracket.
____________________________
Tim Zimmer
2.3L Stroker, GT4088R, AEM EMS, etc.
Offline
Old 08-29-2008, 11:11 PM   #5 (permalink)
Proven Member
Supa Dexta's Avatar
Region: Western Canada
Reputation: Supa Dexta is an unknown
I've seen it where the bolts weren't tight on the tranny mounts for the cables, but that generally makes it near impossinble to get into R and 5th.. Make sure al mounts are tight (don't over tighten then on the tranny, they will strip) Also check the shifter base itself in the car. And if everything is tight with those, then onto the cables.
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
shifting problems 1st,2nd then 4th J-speed99 Automatic Tranny 0 01-19-2006 02:46 PM
bm trannny lsd-now shifting is screwed up galant5spd Drivetrain Tech 10 01-06-2005 03:08 PM
1st gen. gear shifting... siberthugd Drivetrain Tech 1 06-20-2004 02:48 PM
GVR4 1st gear is weaker than the DSM 1st! spoolints04 Drivetrain Tech 6 03-02-2004 07:26 AM
Best year 1st gen, 1st or 2nd cant deside pimpthatride Newbie Forum 10 07-07-2002 03:27 PM
Page generated in 0.11760712 seconds (71.94% PHP - 28.06% MySQL) with 10 queries
