Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Drivetrain Tech
Drivetrain Tech Transmission, clutch, flywheel, driveshaft, gears, differentials, transfer case, shifter, etc.
Reply
LinkBack Thread Tools
Old 06-21-2008, 04:44 PM   #1 (permalink)
Proven Member
Region: Gulf Coast
Classifieds Rating: (0)
Reputation: kchaazz is an unknown
Pedal Assembly Differences
Hello, all.
Well, I had my pedal assembly welded a while back to correct the usual issues. It worked okay for a year or so but now Ive got slop again somewhere else in the assembly and have decided to just swap assemblies since the old one is already welded and there is no going back.
I went to the junk yard today to pull an assembly. All the dsms there are nt 1.8 cars. Most of the PA's were worn, but I found one in a 93 1.8 car that was pristine, no play whatsoever. Now to the point: the pedal assembly is identical in appearance to my awd 90 assembly in every way exept that the large, coiled retention spring is non existant on this "new" assembly. Is this spring just not used on 92 and up cars or is it just not used on nt 2.0 and 1.8 cars? In theory I could just take the one off my awd but the lever on the new one doesnt have the extra length and the hole for the end of the spring to go into!! Id hate to put this sucker in only to have to rip her back out again!!! Perhaps someone with a 92- 94 1g turbo could check for the presence of this spring?
Thanks, Charles
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 06-22-2008, 08:53 PM   #2 (permalink)
Proven Member
Supa Dexta's Avatar
Region: Western Canada
Reputation: Supa Dexta is an unknown
Yeah there is a difference in them there. Also they normally don't have the cruise switches and whatnot. I'm not sure what the difference is for with that spring though, I wouldn't use it myself, just because it must be for a reason.. stronger clutch?.
Offline
Old 07-10-2008, 11:48 AM   #3 (permalink)
Proven Member
4pistons's Avatar
Region: Midwest
Reputation: 4pistons is more helpful than not
The coiled spring was used only on the turbo cars. Why, I don't know. It's not a very good design IMHO.
I cut the coil spring pocket off to get better access to the clutch adjustment, and put a straight tension spring from the pedal up to some small holes in the brace under the dash, like the n/a cars do. Now the pedal comes all the way up every time, unlike what happens sometimes with the coil.
I've been driving on it for over 5 years this way. No problems.
Rick - '91 GSX
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
shifter assembly differences need help fast madscientist323 Newbie Forum 3 11-23-2004 05:18 AM
Clutch pedal assembly UndergroundR32 Drivetrain Tech 0 03-09-2004 06:21 AM
Pedal Assembly 2GStreeT Drivetrain Tech 0 08-10-2003 07:51 PM
clutch pedal assembly awd92tsi Problem Diagnosis 0 01-27-2003 07:00 PM
Page generated in 0.12992001 seconds (61.38% PHP - 38.62% MySQL) with 10 queries
