1g 91 fwd 2nd gear grind
xtreme-elements
139
Jan 4, 2007
eighty four, Pennsylvania
ok so here is my deal.. i have a 1991 eclipse fwd turbo..
i did a 5 speed conversion to it. since doing that, i get a "raking" or grinding when going from 1st to 2nd, and from 3rd to 2nd.. no other gears do it..
also if i drive slow and normal, (not getting in it) it wont grind, but if im slamming gears, its a little worse...
i got all the parts from different guys in my area... trans from one guy, cables, slave etc from another...
i was told its prob a 1990 trans in a 1991 car with all 1991 5 speed cables etc...
how do i tell if the cables are 1990 or 1991 to 1994???
^ +1
The 90 shifter is slightly different from the 91+ shifters but with the cables adjusted you should not have any problem. The shifter arms on the transmissions are also different between the 90 and 91+ but once again with the cables adjusted right there should not be a problem. If the cables were out of adjustment then the car would not go into any gear or just a few.
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
  • For sale FIC 1220 Injectors AEM 320lph fuel pump with rewire kit
    FIC 1220 Injectors AEM 320lph fuel pump with rewire kit. 450 shipped to the lower 48 states.You...
    • elocneas
  • For sale 4G63 Bastard 20g
    Bastard 20g turbo Like New
    • arodgst
  • For sale 2g 97 GSX part out
    Ex-wife's project car part-out. Will be updating the list over the next few weeks and adding...
    • Type1DSMr
