HELP SOMEONE ANYONE! PLEASE PLEASE! I have a Flywheel need!
FenixTX717
185
Oct 10, 2004
k-town, Wisconsin
Hey everyone and anyone....I im in dying need of help. Can someone tell me is there a difference in Flywheels from a 7bolt AWD vs. 7bolt FWD?!
if so is there anyone local or does anyone know someone with a FWD 7bolt flywheel either aftermarket or stock thats already resurfaced?! here is my link to my other add or whatever i need help asap!
I bough a 7bolt exedy 14lb flywheel from a guy on here, but i didn't know that there was a difference between AWD and FWD.....i need this like yesterday! i'm without a car and I have to get this done because I start a new job and I just moved out of town!
I'm locted in Janesville, WI if anyone can help me and my buddy out that'd be great....we installed everything but if we can get this done faster that would be even better.....it took us like a total of 10+ working hours to do everything just to come to find out that it doesn't work! :(
[email protected] 608-449-2124 Cong is the name.....thanks guys and gals!
http://www.dsmtuners.com/classifieds/showproduct.php?product=64078
There's no difference between AWD and FWD flywheels.
Yes there is! Flywheels for AWD and FWD are differnt and also different for 6 bolt and 7 bolt. Clutches are the same for all AWD, FWD, 6 & 7 bolt.
Fidanza Flywheel Part #s
Eclipse 89-92 2.0L T 6-Bolt FWD 161651
Eclipse 89-92 2.0L T 6-Bolt AWD 161691
Eclipse 92-99 2.0L T 7-Bolt FWD 161781
Eclipse 92-99 2.0L T 7-Bolt AWD 161731
big differnce between flywheels dont let anyone tell you diffrent the fwd is a little smaller same with clutches just as synthetek said make sure you get the right one or it will not fit
No, the FWD GS-T fWs are bigger in diameter, so if you stick an AWD FW in a FWD car, the starter will not be able to make contact with the FW ring gear. They all use the same pressure plate and disks though. The reason the FWD FW is bigger in diameter is because the GS-T bell-housing is bigger.
Jack
Yes all FWD flywheels are bigger in diameter. AWD flywheels are smaller to clear the output shaft for the t-case. If you are not sure on your info then dont say anything. Misinformation is very bad and could cost people money and or time.
thanks so far guys.....that's what my buddy said....FWD are a little bigger and the AWD are a little smaller.....
so now i'm stuck with a brand new exedy 14lb AWD flywheel and my factory FWD flywheel is messed up ### i didn't think i needed it so it's cracked ### i dropped it.....so now i need a flywheel asap! n e one know where i can get one and if anyone wants to buy mine for a decently cheap price?!
