Tranny Knotchy!
98RedGs
6,239
7
Sep 14, 2002
Bogalusa, Louisiana
I have a 98 eclipse gs as you know.
Its a 5 spd...
Now here comes my problem...
From 1 - 2 its a little knotchy...
From 2 - 3 its fine
From 3 - 4 its ok
From 4 - 5 its a little bit knotchy... (NOT BAD!)
what do you think it is?
i called mitsubishi and they told me that it is probably the clutch and that it may need replacing... or possibly a TO bearing...
i know for a fact! the shop that is closest to me dosent actually like working on any modified cars!
what should i do?
It's easy to change the fliud. There is a drain bolt on the bottom of the tranny.
After drained. take out the fill bolt on the front of the tranny and refill. with a long tube and a funnel until the fluid comes out of the hole. Done.
I thought it was, and i called the local dsm lot.
The man told me he has never heard this and that he has worked there 38+ years and hes never heard the problems with mitsu trannys...
I was like *RAISE THE BS FLAG*.....
But thats another story...
So a gm dealership keeps this fluid right? (should im thinking)
  • For sale 1g Door cards
    Grey very good condition, pick up only
    • 93 talon tsi awd
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
