Differance between a faceplate, 6-puck, and 4puck
avw0516
187
Jan 23, 2005
cleveland, Ohio
OK, I know that this is probably a newbie question, but I couldn't find the answer anywhere. Anyway I am looking to get an act2600 and apparrantly I have 3 choices: fullfaceplate, 6-puck, and 4puck. The full faceplate holds the least amount of torque so why is it the most expensive. I would like to get the 6-puck, but is there an advantage of the full faceplate. Thanks for the help guys.
-Andrew
-Andrew
The full face(street disc) is probably the best way for you to go. It will be the best driving clutch out of the 3 and to be honest, you are along way from needing anything more. The 4 puck and 6 puck from act have a solid center, not sprung so they are very aggresive and a pain in the ass to drive on the street. They are also very hard on drivetrain parts so count on numerous reapairs of broken ceter diffs, u-joints, etc if you havent already replaced or upgraded them.
I still run the street disk and it is holding up fine. It has been in my car for a few years and I am just now starting to make enough power for it to slip on gear changes. Your current setup will not overpower a street disk with the 2600pp.
Another newbie question... I am assuming that by 2600pp you mean pressure plate, that comes with the clutch and all for like $400 right or is that another expense?
I was talking about the pressure plate which is part of the kit. Only other expenses I would recommend is a new clutch fork for the tranny and a braided clutch line.
Alright, thanks a lot for the help. So even if I build the car up enough to run low 12's I will still be fine with the faceplate right?
Mine is still holding and Im guessing it will run in the 11's. I havent run it it quite a while but with the old turbo, it ran low 12's with no issues. I will hope to see what it will run in the next couple of weeks.
Thanks so much, I have decided to go with the faceplate so that if I do end up wrecking anything it won't be my tranny and my car will still be streetable. Thank you 92awddsm
