Upgrade Slave Cylinder?
Just wondering because i put the SBR 3500 in with a lighted flywheel and it is giving me a hard time engading, i think it might be the slave cylinder going, was just wondering if i can upgrade it to something better than stock, but if stock is all they have to offer than guess it will do.
Adjust your clutch pedal.
Crawl up under your dash, right behind your clutch pedal there's a rod that goes to your master cylinder. There's a locknut on that, it turns right to loosen, then thread that rod until you engage right around the halfway point in the pedal travel. Make sure you tighten the locknut back down.
