Friction modifier
Status
Not open for further replies.
90gs-turbo
70
Dec 1, 2004
colo,springs, Colorado
I was reading off of auto consumier guide..I read that 1st gens need a bottle of friction modifier added to the oil through the speedometer gear onpening ..I sometims get grinding putting it into 1st from nuetral and sometimes 1st to 2nd..Would friction modifier help with the gears moving smoothly and not grinding :) ((((Poor transmission shift: Manual transmissions in which the shifter does not move smoothly between gears need a bottle of friction modifier added to the oil through the speedometer gear opening. (1990-92)00))))
Replace your tranny fluid with Pennzoil Synchromesh.
Search if you need details.
Not much of the stuff that came out ten years ago is still current.
Status
