93 FWD tranny with a 91TSI Motor
93ESTalon
37
Nov 13, 2003
Wytheville, Virginia
I searched and searched and frankly i'm tired...very tired. I found some similar cases but not any dealing with my yr/model and 6/7bolt situation. I'm replacing my 93 N/A motor(7bolt) with a 91 TSi (6bolt) motor. I'm doing the whole turbo conversion. Can i use my 93 FWD tranny? The engine is a 6 bolt but the tranny went on my 7 bolt motor. If not. Can i bolt on the AWD tranny and halfshafts and just dich the Transfer case. Or will i have to find a FWD tranny for a 6bolt? I'm know a lot of this tranny/6/7bolt stuff has been beaten to death but i'd rather ask to be on the safe side and save myself the trouble of finding out the hard way. :rolleyes:
Any help from you guys would be greatly appreciated.
Thanks
Tyler :talon:
So it should bolt on with no problem. Will i still be able to use my 6bolt turbo flywheel and clutch or will i have to find a 6bolt N/T flywheel? I heard that since the flywheel and clutch are bigger on the T that it won't clear the Bell housing. I hope i can use the T Flywheel and everything because i just had it resurfaced for 45$ (previous owner slipped the Shite out of the clutch). Thanks for the reply man and good luck on your conversion.
Tyler :talon:
