rdrkt
- 1,540
- 3
- Apr 20, 2002
Baltimore,
Maryland
Hey guys just wanted to tell you about my night at the track last night. Friday was the last grudge night at Maple Grove for this season. I was feeling pretty confident that I would do well that night. The weather was just right lows 70s. I replaced my webs street grind with a pair of HKS 272s and I replaced my Br street core with a Spearco 2-216 core all of this was installed and tuned at Wes Hess Racing (HighPsi91) #11 on dsmtimes.org. This was my first time at the track with the new setup so I wanted to see what it would do on pump gas. I like to run at the track with pump gas to get a good baseline and to try and get a handle on what I can beat on the street.
The day started off real poor. I got to the track pretty early and about half way through my run I felt that something was pretty wrong. When I got my slip mph and et were down. I took a look at the safc and I noticed it was off. What I realized about an hr later is that it became disconnected internally. So I opened up the safc and reconnected it and ran a [email protected] literally a minute after I got it working. I only got one other run in that night because people kept spilling all over the track. For my last run temps were in the high 60s or so. I ran a [email protected] on a 1.78 60ft. Not too bad IMHO. All runs were at about 21lbs of boost. Something tells me with a few more passes I may see a high 11 in the 118-119 range. I may also be able to run a lb or two more boost.
My relevant mods are BR57 turbo Diamond Star Motorsports race core, 850cc injectors, TMO ecu, Hes Racing idle air simulator, safc, HKS 272 cams, BJ stage 2 head work and 91 piston 95 rod motor. Now I know that if you narrow down the field enough you can be the best at something. But does anyone know of a pump gas record with a safc? I know that a lot of people have gone a bit better on the Red with pump gas but usually they have a VPC too. I'm hopping that if I add some c16 I should be able to see another 8-12mph and I plan on doing that in another week or two at Cecil when it gets a bit cooler.
As for the future I have a Haltech sitting on the couch right now and a Maguns 4G64 in the mail
I'm getting tired of having to fight the ecu I'm thinking that once I get things all tuned on the Haltech I should see a healthy increase in pump gas power just by being able to control timing and not having to worry about the knock sensor.
I havent been to the dyno yet But if you throw my numbers into a hp calculator it should be well over 400hp to the wheels. I am still running full weight. By full weight I mean cold running ac, bumpers, all my seats, and heavy ass driver.
I would really like to take the opportunity to thank Wes (HighPsi91) he has done a really good job at trying to fit me in with all his other work including his own 10 sec car. Ok guys thanks for listening.
I'm getting tired of having to fight the ecu I'm thinking that once I get things all tuned on the Haltech I should see a healthy increase in pump gas power just by being able to control timing and not having to worry about the knock sensor.I havent been to the dyno yet But if you throw my numbers into a hp calculator it should be well over 400hp to the wheels. I am still running full weight. By full weight I mean cold running ac, bumpers, all my seats, and heavy ass driver.
.. j/k Dave..
