guys..
Phil1320
2,256
41
Dec 9, 2002
Rocky Hill, Connecticut
did final tuning on the Talon last Wed. night on the Dynapacks here in CT at XX Tuning....a local import speed shop.
First pull was 267HP..........untuned.
The car ended up with 284.7HP@5983rpm and 271.1TQ@5038rpm. Boost was averaging around 19psi.........with a spike to 21 as I hit the pedal. So, the car feels nutty........and is running well. Hopefully, we will run well this Friday. I have from 10am to 4pm to run down the strip in less than 12.0. I'll keep you guys posted.........
Phil1320
sweet! great numbers, i wish you luck at the track! so you think around 19psi is the magical 14b boost number? i've been trying anywhere from 18-20psi with luck, i'm wondering if i should try 21-22 psi? the temps at brainerd on wensday should be in the 40's, do you think i should try more boost with these temperatures? i'm running a massive front mount right now to cool the 14b's steam. just curious, what kind of base timing advance are you running?
I actually think that 20 is the perfect max boost........earlier this year on the dynojet at Altered, here was the break down
19 psi 257HP and 275TQ
20 psi 263.1HP and 281.7TQ
21 psi 265.9HP and the same TQ as 20 psi
so.........there is a good jump in WHP from 19 to 20 psi.....but 20-21 is not that big at all.............and torque was the same......
I'd roll 20psi................
Phil1320
If I remember correctly, I think Phil's car weighs in the neighborhood of 2580 lbs +/- I remember reading that in another post. Talk about weight reduction!! :D
damn, good numbers. I'm hoping to pull something like that once I get my car to a dyno in a month.
yep..11secDSM is right......thats about where the car is - 2580, so, with me 2765 or so, total weight.........
by the way, thanks quickersol!
Phil1320
  • For sale 2g 2G DSM ECU
    Came off a 1997 GST M/T. Stock ECU
    • Stizzydrew
  • For sale 1g 90-91 Talon pass taillight.
    Pass taillight for 90-91 Talon. Good condition. No breaks or cracks. Will buff up nice...
  • For sale 2g 2G Manual Window Assemblies, Door Panels, & Hardware
    2G Manual Window Assemblies, Door Panels, & Hardware $250 + shipping and paypal feesYou must...
  • For sale 2g 2GB Talon Wing ( 3rd brake light included )
    2GB Talon Wing $90* pick up only in 08096 NJ * 3rd brake light includedYou must be...
  • For sale 2g 2GB Talon Front Bumper
    2GB Talon Front Bumper $200* pick up only in 08096 NJ * tear on the bottom side, picturedYou...
