need some good FWD street tires.
myblack98gst
578
Jun 22, 2003
Elizabethtown, Kentucky
Okay I have a problem I am tired of not being able to drive my car that I have been working so hard on..
I am especially tired of not being able to accept a run from a stop!!!!!
I have some ..... off brand I think..... tires on the front of my GST they worked great when I got the car never broke loose but now all it does is spin.. 1st gear just a little before 4k and second gear around 5k.
SOOOOO I am in the market for a good set of drag radials that have decent tread life to them. So I dont have to replace them once every couple of months.
I know I also need to step up to a limted slip diff. but that isn't a option right now.
Let me know what you use and how you like them.
I have a profec B already..... that sucks I want the high boost in first
Well, honestly, you are going to have to get over that want for high boost in first. Trust me it does more harm then good. But getting to the point if you want some decent tires, go with the Perelli Pzero Neros. They are all weather tires, and do their job pretty damn well. I've been running around on them and I'm quite satisfied.
LOL, so you want to run high boost in first gear in a FWD 3200lb car....no tire will stick that down.
Lower the 1st gear boost...or just learn to butterfly the clutch/throttle (AKA learn to drive a FWD...learning to drive will also supplement the LSD for a long time). Check into some BFG G-force tires KDWS...400 treadlife, great grippage.
