d landa
- Oct 30, 2002
I was wondering if it would be possible to run 11's on a stock 14b turbo in a fwd. I have a 90 laser fwd turbo and i have been thinking if it would be possible at all. The car as it sits now weighs 2100lbs and i still plan to remove more weight from it to get it to at least 1900lbs as you might be thinking the car is completely gutted not streetlegal no lights nothing. The car will have the suspension set up with slicks and skinnies in the rear. The mods it will have be ported turbo and ex. manifold, o2 eliminator with open exhaust,mbc set at 20-22 psi on race gas, small fmic and so on. I will not run nitrous in it though.I have tried using those horspower calculators and they say that in a 1900 lb car youll need 230 hp at wheels i know those hp calculators arent accurate. But its seems to me that it should be possible since the car will be really light. What do you guys think?
