talon913
- 244
- Nov 21, 2008
olathe,
Kansas
ok i was at the strip with my 90 laser rs t.and i ran a 15.02 at stock 8-10psi 99mph and a 2.5 60 ft.well my question is was that slow for a stock run on a good 14b??then i turned the boost up to 12psi and ran a 15.2 which was because my clutch was slippin realy bad is it normal for the clutch to slip afte 8psi or is my clutch jus not holding that much boost?? what should i do to get me to break mid 14s??
..well i guess my clutch has to go what do you guys suggest for a clutch??
