Violater101
- 1,051
- Apr 16, 2002
I guess its time for some drag radials. As you can see from the log below, my 1.8th mile time is killing me. I should be trapping somewhere at least around 90pm, but due to traction issues, i'm losing bigtime mph in between shifts and never even got more than 60% throttle. Nonetheless, I'm picking up big power up top (around 29mph). Hopefully i'll see around 119 or 120 when its all said and done. This was on 23psi and C16. Went through the traps 13.85@114 (60ft was a 2.41). This was my first time to ever run racegas so I had to play with the settings. Overall, I was fairly happy despite the bad 1.8th mph.
RPM Speed Knock Timing TPS FJOWB
1) AirFlowLb (Lb/min)
4281 * 0 * 0 * 36.1 * 21 * 12.4 * 1.8
4325 * 0 * 0 * 35 * 26 * 12.4 * 4.9
4545 * 0 * 0 * 31.1 * 26 * 12.3 * 7
4741 * 0 * 0 * 32.2 * 26 * 12.3 * 7.5
4864 * 0 * 0 * 34.3 * 26 * 12.6 * 7.8
4896 * 0 * 0 * 34.3 * 26 * 12.6 * 7.8
4845 * 0 * 0 * 34.3 * 26 * 12.6 * 7.8
4729 * 0 * 0 * 33.3 * 27 * 12.6 * 7.9
4607 * 0 * 0 * 31.1 * 30 * 12.7 * 8.3
4524 * 0.4 * 0 * 30.1 * 30 * 12.9 * 8.8
4448 * 0.8 * 0 * 29 * 30 * 12.9 * 8.9
4381 * 1.2 * 0 * 28.3 * 30 * 12.8 * 9
4310 * 1.2 * 0 * 27.3 * 30 * 12.8 * 9.1
4223 * 2.5 * 0 * 26.2 * 30 * 12.6 * 9.1
4157 * 3.7 * 0 * 25.1 * 30 * 12.5 * 9.1
4094 * 5.4 * 0 * 25.1 * 30 * 12.5 * 9.1
4028 * 5.8 * 0 * 24.1 * 30 * 12.4 * 9.1
3952 * 6.2 * 0 * 24.1 * 31 * 12.3 * 9
3878 * 6.2 * 0 * 24.1 * 31 * 12.3 * 9
3807 * 6.6 * 0 * 25.1 * 35 * 12.4 * 9.2
3784 * 7 * 0 * 24.1 * 37 * 12.5 * 9.6
3811 * 7.5 * 0 * 24.1 * 39 * 12.6 * 9.9
3886 * 8.3 * 0 * 23 * 40 * 12.5 * 10.3
3981 * 9.1 * 0 * 22 * 40 * 12.3 * 10.7
4054 * 10.4 * 0 * 21.3 * 40 * 12.1 * 11.3
4076 * 10.8 * 0 * 20.2 * 40 * 12.2 * 11.6
4067 * 11.2 * 0 * 19.1 * 40 * 12.2 * 12
4058 * 12.8 * 0 * 18.1 * 40 * 12.1 * 12.2
4019 * 14.5 * 0 * 17 * 40 * 11.9 * 12.4
3952 * 17.8 * 0 * 17 * 40 * 11.7 * 12.6
3910 * 19.5 * 0 * 16 * 40 * 11.5 * 12.7
4116 * 21.1 * 0 * 16 * 40 * 11.3 * 13.4
4167 * 21.5 * 0 * 17 * 40 * 11.3 * 13.8
4181 * 22 * 0 * 16 * 40 * 11.5 * 14.3
4281 * 23.2 * 0 * 14.9 * 40 * 11.5 * 15
4448 * 24 * 0 * 16 * 41 * 11.5 * 15.9
4502 * 25.3 * 0 * 15.3 * 41 * 11.6 * 16.6
4699 * 25.7 * 0 * 14.2 * 42 * 12 * 18.1
4717 * 26.1 * 0 * 15.3 * 43 * 12 * 19.1
4941 * 26.5 * 0 * 14.2 * 43 * 12 * 20.8
4889 * 26.9 * 0 * 15.3 * 43 * 12 * 21.9
5289 * 28.2 * 0 * 15.3 * 43 * 11.9 * 24.1
5365 * 29 * 0 * 16 * 43 * 11.8 * 26.4
5769 * 31.1 * 0 * 18.1 * 43 * 12 * 29.3
5934 * 32.3 * 0 * 18.1 * 43 * 12 * 31.5
6240 * 34.4 * 0.4 * 20.6 * 43 * 11.9 * 32.1
6649 * 35.2 * 0.4 * 20.6 * 42 * 12 * 33.6
6732 * 37.3 * 0.4 * 21.6 * 42 * 11.8 * 32.7
7198 * 38.5 * 0.4 * 21.3 * 41 * 12.3 * 33.7
7022 * 39.8 * 0.4 * 22.7 * 41 * 12.2 * 32
7560 * 40.2 * 0 * 23 * 40 * 12.8 * 33.1
7367 * 40.6 * 0 * 24.1 * 42 * 12.6 * 31.8
7796 * 41.4 * 0 * 21.6 * 43 * 13.2 * 34.5
7253 * 41.8 * 0 * 24.1 * 43 * 13.8 * 32.4
7500 * 40.2 * 0 * 32.2 * 0 * 13.5 * 14.4
7062 * 38.1 * 0 * 44.2 * 0 * 12.3 * 4.5
6868 * 34.8 * 0 * 44.2 * 0 * 13.1 * 2
6720 * 33.5 * 0 * 44.2 * 0 * 14.4 * 2.3
6556 * 32.3 * 0 * 44.2 * 0 * 16.3 * 1.8
6432 * 32.3 * 0 * 44.2 * 0 * 17.6 * 1.9
6292 * 32.3 * 0 * 44.2 * 14 * 15 * 1.4
6260 * 32.7 * 0 * 44.2 * 43 * 14.2 * 9.2
6466 * 33.1 * 0 * 39.3 * 51 * 13.9 * 17.8
6614 * 33.5 * 0 * 31.1 * 53 * 15 * 21.3
6522 * 33.5 * 0 * 28.3 * 44 * 13.1 * 23.6
6292 * 34 * 0 * 37.1 * 32 * 12.2 * 18.3
5962 * 34.4 * 0 * 28.3 * 33 * 13.2 * 19
5699 * 34.8 * 0 * 26.2 * 36 * 12.2 * 20.1
5482 * 34.8 * 0 * 22 * 37 * 12.5 * 22.5
5312 * 35.2 * 0 * 19.1 * 38 * 12.5 * 23.2
5158 * 35.6 * 0 * 16 * 38 * 12 * 24.2
5007 * 36.9 * 0 * 14.2 * 39 * 11.9 * 24.5
4928 * 37.7 * 0 * 14.2 * 42 * 11.8 * 25.3
4954 * 38.5 * 0 * 14.2 * 43 * 11.8 * 27.1
5007 * 38.9 * 0 * 14.2 * 44 * 11.8 * 28.9
5061 * 39.3 * 0 * 14.2 * 44 * 11.8 * 29.5
5116 * 40.6 * 0 * 14.2 * 44 * 11.9 * 30
5151 * 41.4 * 0 * 15.3 * 44 * 12 * 30.2
5208 * 42.7 * 0 * 15.3 * 44 * 12.1 * 30.5
5245 * 43.1 * 0 * 15.3 * 45 * 12.2 * 30.8
5289 * 45.1 * 0 * 16 * 46 * 12.3 * 31.6
5443 * 46.8 * 0 * 16 * 49 * 12.3 * 33
5656 * 50.5 * 0 * 16.7 * 52 * 12.6 * 34.7
5943 * 52.6 * 0 * 20.2 * 55 * 12.7 * 37
6399 * 57.2 * 0 * 20.9 * 58 * 12.7 * 38.8
6625 * 59.6 * 0 * 22 * 59 * 12.6 * 40.1
7062 * 64.2 * 0 * 22 * 59 * 12.7 * 42.4
7184 * 66.3 * 0 * 22 * 59 * 12.5 * 42
7606 * 70 * 0 * 22 * 58 * 12.7 * 43
7684 * 71.7 * 0 * 19.1 * 59 * 12.5 * 41.6
7895 * 72.9 * 0 * 18.8 * 58 * 12.1 * 42.3
7530 * 72.5 * 0 * 18.4 * 58 * 13.7 * 35.7
7591 * 72.5 * 0 * 20.2 * 58 * 13.2 * 37.6
7700 * 72.9 * 0 * 21.3 * 58 * 14.1 * 41.4
7653 * 73.3 * 0 * 17 * 58 * 12.6 * 40.8
7637 * 73.3 * 0 * 22 * 58 * 20 * 37
7653 * 73.3 * 0 * 19.1 * 58 * 14.1 * 40
7748 * 73.3 * 0 * 20.2 * 58 * 12.6 * 41.7
7440 * 72.9 * 0 * 17.4 * 58 * 12.3 * 39.5
7653 * 72.5 * 0 * 22 * 58 * 20 * 37.5
7591 * 72.5 * 0 * 20.2 * 58 * 14.1 * 40
7812 * 72.9 * 0 * 21.3 * 58 * 12.8 * 41.9
7339 * 72.9 * 0 * 17.4 * 58 * 13.3 * 38
7515 * 72.5 * 0 * 22 * 59 * 14.6 * 36.8
7515 * 72.5 * 0 * 22 * 59 * 14.7 * 40.3
7764 * 72.9 * 0 * 21.3 * 59 * 12.9 * 42.2
7426 * 71.2 * 0 * 18.4 * 59 * 12.8 * 40
7606 * 69.2 * 0.7 * 21.3 * 21 * 20 * 21.8
7411 * 64.2 * 0 * 44.2 * 0 * 12.9 * 7.2
7239 * 61.3 * 0 * 44.2 * 0 * 14.1 * 2.6
7022 * 58 * 0 * 44.2 * 0 * 15.3 * 1.5
6868 * 57.6 * 0 * 44.2 * 2 * 18.4 * 1.6
6757 * 57.2 * 0 * 44.2 * 47 * 19 * 5.7
6219 * 58 * 0 * 39.3 * 88 * 16.2 * 19.1
5388 * 58.8 * 0 * 24.1 * 94 * 18.6 * 21.2
4459 * 61.3 * 0 * 14.2 * 94 * 13.6 * 22
4502 * 63 * 0 * 11 * 94 * 11.9 * 22.4
4015 * 63 * 0 * 11.4 * 94 * 11.2 * 21
4247 * 61.3 * 0 * 10 * 94 * 10.9 * 21.8
4417 * 60.5 * 0 * 11 * 94 * 10.6 * 23
4185 * 61.3 * 0 * 10 * 94 * 10.6 * 23.5
4366 * 62.1 * 0 * 11 * 94 * 11.3 * 24.9
4417 * 62.1 * 0 * 11 * 94 * 11.1 * 25.9
4335 * 63 * 0.4 * 9.6 * 94 * 11.3 * 26.4
4475 * 63.8 * 0.4 * 10.7 * 93 * 11.3 * 27.3
4475 * 64.6 * 0 * 11 * 94 * 11.3 * 27.4
4480 * 64.6 * 0 * 11 * 94 * 11.6 * 27.2
4573 * 65 * 0 * 11 * 94 * 11.7 * 27.6
4568 * 65.4 * 0 * 11 * 94 * 12 * 27.9
4624 * 65.9 * 0 * 11 * 94 * 12 * 28.1
4670 * 65.9 * 0 * 12.1 * 94 * 12 * 28.5
4723 * 66.3 * 0 * 12.1 * 94 * 12 * 28.8
4711 * 66.7 * 0 * 12.1 * 94 * 12.2 * 28.7
4789 * 67.1 * 0 * 13.1 * 94 * 12.3 * 29.1
4814 * 67.9 * 0 * 13.1 * 94 * 12.4 * 29.2
4864 * 68.8 * 0 * 13.1 * 94 * 12.3 * 30
4889 * 69.6 * 0 * 13.1 * 94 * 12.3 * 30.2
4928 * 69.6 * 0 * 14.2 * 94 * 12.3 * 30.5
4980 * 70.4 * 0 * 14.2 * 94 * 12.3 * 30.9
5000 * 71.2 * 0 * 14.2 * 94 * 12.3 * 31.3
5047 * 72.1 * 0 * 14.2 * 94 * 12.2 * 31.8
5081 * 72.1 * 0 * 14.2 * 94 * 12.4 * 32.1
5137 * 72.9 * 0 * 14.2 * 94 * 12.4 * 32.6
5180 * 73.7 * 0 * 15.3 * 94 * 12.2 * 33
5216 * 75 * 0.7 * 15.3 * 94 * 12.2 * 33.3
5230 * 75.4 * 0.7 * 15.6 * 94 * 12.3 * 33.5
5304 * 75.8 * 0.7 * 15.3 * 94 * 12.3 * 34.1
5319 * 75.8 * 0.7 * 15.3 * 94 * 12.1 * 34.4
5357 * 76.2 * 0.7 * 15.3 * 94 * 12.3 * 34.6
5427 * 76.6 * 0.7 * 16.3 * 94 * 12.2 * 34.9
5435 * 77.4 * 0.7 * 16.3 * 94 * 12.1 * 35.1
5482 * 77.9 * 0.7 * 16.3 * 94 * 12.3 * 35.3
5539 * 78.3 * 0.7 * 16.3 * 94 * 12.4 * 35.6
5556 * 78.3 * 0.7 * 16.3 * 94 * 12.4 * 35.7
5631 * 79.1 * 0.7 * 17.4 * 94 * 12.4 * 35.9
5631 * 79.9 * 0.7 * 17.4 * 94 * 12.3 * 35.9
5673 * 80.8 * 0.4 * 17.7 * 94 * 12.3 * 36.2
5716 * 81.2 * 0.4 * 17.7 * 94 * 12.4 * 36.4
5752 * 81.6 * 0.7 * 17.4 * 94 * 12.4 * 36.6
5796 * 82 * 0.7 * 19.5 * 94 * 12.5 * 36.8
5841 * 82 * 0.7 * 19.5 * 94 * 12.4 * 37.2
5878 * 82.8 * 0.7 * 19.5 * 94 * 12.3 * 37.3
5915 * 83.7 * 0.7 * 19.5 * 94 * 12.3 * 37.5
5971 * 84.9 * 0.7 * 20.6 * 94 * 12.3 * 37.7
* 1/8th mile 84.6 * * * * *
5981 * 85.3 * 0.7 * 20.6 * 94 * 12.5 * 37.9
6029 * 85.7 * 0.7 * 20.6 * 94 * 12.5 * 38.4
6048 * 85.7 * 0.7 * 20.6 * 94 * 12.5 * 38.4
6088 * 86.6 * 0.7 * 20.6 * 94 * 12.4 * 38.7
6168 * 87.4 * 0.7 * 20.6 * 94 * 12.6 * 39.1
6178 * 88.6 * 0.4 * 20.9 * 94 * 12.4 * 39
6198 * 89 * 0.4 * 20.9 * 94 * 12.5 * 39.1
6260 * 89.5 * 0.4 * 20.6 * 94 * 12.6 * 39.5
6281 * 89.5 * 0.4 * 21.6 * 94 * 12.5 * 39.6
6303 * 89.9 * 0.4 * 21.6 * 94 * 12.5 * 39.7
6345 * 90.3 * 0.4 * 21.6 * 94 * 12.5 * 39.9
6410 * 90.7 * 0.4 * 21.6 * 94 * 12.5 * 40.3
6443 * 90.7 * 0.7 * 21.3 * 94 * 12.4 * 40.4
6454 * 91.5 * 0.7 * 21.3 * 94 * 12.6 * 40.5
6477 * 92.4 * 0.7 * 21.3 * 94 * 12.5 * 40.7
6556 * 93.6 * 0.7 * 21.3 * 94 * 12.5 * 41
6567 * 94 * 0.7 * 21.3 * 94 * 12.5 * 41.1
6591 * 94.4 * 0.7 * 21.3 * 94 * 12.7 * 41.3
6649 * 94.4 * 0.4 * 21.6 * 94 * 12.5 * 41.4
6637 * 94.4 * 0.4 * 21.6 * 94 * 12.5 * 41.4
6720 * 94.4 * 0.7 * 21.3 * 94 * 12.5 * 41.8
6708 * 95.7 * 0.7 * 21.3 * 94 * 12.5 * 41.7
6769 * 96.9 * 0.7 * 20.9 * 94 * 12.7 * 41.9
6793 * 98.2 * 0.7 * 21.3 * 94 * 12.5 * 41.8
6831 * 97.3 * 0.7 * 21.3 * 94 * 12.5 * 42
6881 * 96.5 * 0.7 * 21.3 * 94 * 12.5 * 42
6881 * 97.3 * 0.7 * 21.3 * 94 * 12.5 * 42.1
6944 * 99 * 0.7 * 21.3 * 94 * 12.6 * 42.4
6957 * 99.8 * 0.7 * 21.3 * 94 * 12.6 * 42.4
6970 * 99 * 0.7 * 21.3 * 94 * 12.6 * 42.5
7022 * 99.4 * 0.7 * 21.3 * 94 * 12.5 * 42.4
7022 * 100.6 * 1.1 * 21.3 * 94 * 12.6 * 42.5
7089 * 101.5 * 0.7 * 21.3 * 94 * 12.8 * 42.8
7129 * 101.1 * 0.7 * 21.3 * 94 * 12.6 * 42.7
7129 * 101.1 * 0.7 * 21.3 * 94 * 12.6 * 42.6
7212 * 101.5 * 0.7 * 21.3 * 94 * 12.6 * 42.9
7225 * 102.3 * 0.7 * 21.3 * 94 * 12.5 * 42.9
7198 * 102.7 * 0.7 * 21.3 * 94 * 12.6 * 42.7
7212 * 104 * 0.7 * 21.3 * 94 * 12.5 * 43
7267 * 104.8 * 0.7 * 21.3 * 94 * 12.5 * 43.1
7353 * 104 * 0.7 * 21.3 * 94 * 12.6 * 43.3
7382 * 104 * 0.7 * 21.3 * 94 * 12.5 * 43.3
7339 * 104.8 * 0.7 * 21.3 * 94 * 12.5 * 43
7396 * 105.6 * 0.7 * 21.3 * 46 * 12.4 * 43.2
7282 * 105.6 * 0.4 * 28.7 * 0 * 12.4 * 13.9
7239 * 105.6 * 0 * 44.2 * 0 * 11.1 * 2.4
7075 * 105.6 * 0 * 44.2 * 0 * 12 * 1.6
6944 * 105.6 * 0 * 44.2 * 29 * 12.8 * 2.3
6843 * 105.6 * 0 * 40.3 * 93 * 12.6 * 17.8
6732 * 106 * 0 * 30.1 * 94 * 20 * 25
5507 * 106.4 * 0 * 23 * 94 * 13.8 * 26.9
5403 * 106.9 * 0 * 16 * 94 * 12.5 * 30.9
5466 * 106.9 * 0 * 17 * 94 * 11.7 * 32.1
5419 * 106.9 * 0 * 16 * 94 * 11.4 * 34.1
5482 * 106.4 * 0 * 17 * 94 * 11.5 * 34.8
5459 * 106 * 0 * 17 * 94 * 11.6 * 34.7
5507 * 106.9 * 0 * 17 * 94 * 11.7 * 34.8
5482 * 108.1 * 0 * 17 * 94 * 12.1 * 34.6
5531 * 108.5 * 0.4 * 16.7 * 94 * 12.1 * 35.2
5515 * 107.7 * 0.4 * 16.7 * 94 * 12.1 * 35.1
5580 * 107.7 * 0.4 * 16.7 * 94 * 12 * 35.5
5564 * 108.5 * 0.4 * 17.7 * 94 * 12.2 * 35.4
5589 * 109.3 * 0 * 17 * 94 * 12.3 * 35.8
5614 * 109.3 * 0 * 18.1 * 94 * 12.2 * 35.8
5597 * 109.3 * 0.4 * 17.7 * 94 * 12.2 * 35.7
5639 * 109.3 * 0.4 * 17.7 * 94 * 12.3 * 35.9
5656 * 109.3 * 0.4 * 17.7 * 94 * 12.2 * 35.8
5690 * 110.2 * 0.4 * 17.7 * 94 * 12.3 * 36.1
5690 * 111 * 0.4 * 17.7 * 94 * 12.3 * 36.1
5716 * 111.8 * 0.4 * 17.7 * 94 * 12.3 * 36.1
5716 * 111.8 * 0.4 * 17.7 * 94 * 12.4 * 36.4
5760 * 111.8 * 0.4 * 19.9 * 94 * 12.3 * 36.5
5769 * 111.8 * 0.4 * 19.9 * 94 * 12.3 * 36.6
5778 * 112.7 * 0.4 * 19.9 * 94 * 12.2 * 36.6
5796 * 113.5 * 0 * 20.2 * 94 * 12.2 * 36.6
5823 * 114.3 * 0.4 * 20.2 * 94 * 12.4 * 36.7
* end * * * * *
5823 * 114.3 * 0.4 * 19.9 * 94 * 12.4 * 36.9
5841 * 114.3 * 0.4 * 19.9 * 94 * 12.4 * 36.9
5859 * 114.3 * 0.4 * 19.9 * 94 * 12.4 * 37.1
5869 * 114.3 * 0.4 * 19.9 * 94 * 12.4 * 37.1
5896 * 114.3 * 0.4 * 19.9 * 94 * 12.3 * 37.4
5896 * 115.1 * 0.4 * 19.9 * 94 * 12.3 * 37.3
5924 * 116 * 0.4 * 20.9 * 94 * 12.4 * 37.5
5943 * 116.8 * 0.4 * 20.9 * 94 * 12.3 * 37.7
5952 * 116.8 * 0.4 * 20.9 * 94 * 12.5 * 37.6
5990 * 116.8 * 0.4 * 20.9 * 94 * 12.3 * 37.8
6019 * 116.8 * 0.4 * 20.9 * 94 * 12.4 * 38
6029 * 117.6 * 0.4 * 20.9 * 94 * 12.5 * 38.1
1) AirFlowLb (Lb/min)4281 * 0 * 0 * 36.1 * 21 * 12.4 * 1.8
* end * * * * *
Wouldn't have slicks on, but would have had some DR's.
I'm not going to benchrace etc on my #'s, but I think it's more than 360. Sidenote: I've went 86mph @18psi/16 deg of timing in the 1.8th mile.
