JiveMasterT
- 1,848
- 9
- Jan 3, 2004
Chest of Westerson,
New York
i've never been to the track before, but i've been street racing my car since i got it, so im a good driver, even better reaction time, and i dont think it will be hard for me to adapt to the controlled environment of the track.
i have the stock turbo (yes, i know...)
intake, turbo back exhaust, and solid intercooler pipes. what do you think i can expect to run with this setup? i believe the previous owner also pulled out the bcs restrictor, so i think i need a boost controller. my boost is usually at 15psi, but has gone as high as 17.
so, what can i expect to run with this set up?
edit...
also forgot to mention that i have yokohama avids... i dont know what kind of tires those are and if they will be any good for the track. on the street they work fine though.
edit...
so u can do low 14's with good driving
but it is stock..and according to your profile your FWD and yes AWD compared to fwd is .7
ussually i run 14.5 at 95. So Once clutch is back in order I will run mid low 14
