GPLaserRS
- 305
- 33
- Aug 23, 2005
Grosse Pointe,
Michigan
I have a 1G 6 bolt motor that I'm trying to rebuild on somewhat of a budget, I've got most of what I need to finish. I'm looking for anybody to chime in if you think I'm missing anything, do something different, and suggest someplace to get the machine work done. Let me give a little background on the block I'm using; 6 Bolt motor with less than 60,000 miles on it, BS belt broke and caused the timing to jump and the valves bang into the pistons. Put the motor on an engine stand and it's been there ever since (about 6 yrs now). Anyways, here's what I've been hoarding/stockpiling for a rebuild so far -
2G pistons (complete with pins and rings)
King rod & main bearings
BSE kit
3G lifters
Nitrited I/E valves
EVO VIII valve springs and retainers
Full gasket set
MLS head gasket
Mitsubishi hydraulic tensioner and pulleys
Things I still need -
ARP rod/cam/main/head hardware
Kevlar t-belt
Bronze valve guides
Machine work -
Hot tank the block
Deck the block
Valves lapped
Valve ports reground
Deck the head
Machine the rods for the pistons
Rear balance shaft turned down
Let me know what any of you think?
BSE kit
3G lifters
Nitrited I/E valves
Full gasket set
MLS head gasket
Kevlar t-belt
Bronze valve guides
Machine work -
Hot tank the block
Deck the block
Valves lapped
Deck the head
