97 eclipse spyder new shift solenoids and end clutch and still no overdrive,..need he
97eclipse-spyder
May 7, 2012
flint, Michigan
Have a 1997 eclipse spyder with no overdrive,I have replaced all shift solenoids,end clutches, and tcm and still no overdrive,..any suggestions?
did you check the o-ring on top of the valve body? if its gone so is your reverse. you need that o-rind intact to get pressure for reverse. also have you tried unplugging your tcu to see if you have 3rd and reverse. if have only 3rd its most likely mechanical. solenoids dont have anything to do with reverse. its all mechanical.
