jltcat
- 187
- 2
- Dec 1, 2002
somewhere,
New Hampshire
Went to install a balance shaft removal kit for a 2G DSM. Upon installing in the front cover/oil pump it became evident that the engineering design was not sound. The lateral thrust on the oil pump driven gear will cause premature wear on the aluminum cover. Since oil pump clearences are measured +/- .001" or so clearence between the gears will very quickly go out of spec as the cover bearing surface wears.
This is what we came up with for a solution...(see attachment file)
This design will eliminate the twisting motion on the driven shaft by retaining the large rear bearing to absorb the lateral load on the gear. We realize there may be some advantage to blocking the oil hole in the rear bearing area when you intall the (eliminator kit); but any gains in oil supply will be quickly lost when the bearing surface on the front cover go out of round.
This shaft is fully balanced, and as a result there is no internal harmonics setup by the balance shaft so a very tight tolerance is possible thereby allowing for minimal oil loss from the large bearing, while at the same time retaining the tolerances in the oil pump.
