djmidnite
- Oct 30, 2002
High Hill,
Missouri
The engine has been rebuilt before, it has about 60,000 miles on rebuild.
Ok I figure this is what I need:
Crank checked/machined
rods checked
gasket set
rod bearings
timing belt (tensioner new at rebuild)
cometic head gasket
Will I be better off getting new rings and cross hatching the bores?
Should the main bearing be replaced as well?
Should I try to get the balance shaft removal done this time? Had a heck of a time trying to get it done the first rebuild without success. Is there anything I'm missing?
rods checked
gasket set
rod bearings
cometic head gasket
