Spoolin18
- 836
- Feb 2, 2009
Albany,
Kentucky
Here is the story, I noticed my car will idle low when you come to a stop, I also noticed a slight miss at idle. The car is completly stock, never seen more than stock boost. It has 95,800 on the clock. I took it to my mechanic, he did a compression test and the results are as follows. #4=145, #3=142, #2=138, #1=110. It holds excellent oil pressure, better than any dsm I've ever seen and i've seen plenty of them. It holds about 18-20 inch HG vaccumm at idle and the needle will slowly snap back when you rev it. But I do have a prosport boost/vac gauge, not sure if that plays a part in it or not. I heard their gauges aren't the best in the world. It has good power. I tried the hill/stomp gas pedal scenario and it didn't smoke. It has sit a long time, probably put 20 miles on it since march. It smokes a little blueish-whiteish color at startup and will do so at idle until it is drove for a few minutes, the smoking goes away. My mechanic has narrowed it down to either a failing headgasket or a valve not sealing all the way on the #1 CYL. I meant to ask him if the compression test was done at a cold start, or warm. I'm thinking it might be a bad seal and when it gets warm, the seal soaks up the oil and the valve seals all the way, but I can't say for sure since I don't know how the test was performed. In any case, could it be rings? He was going to do a t-belt job, until we found this problem. The timming was off slightly, but when they adjusted it, it was still low. I need help and guidance. Should I tell him to pull the head and see for sure what the heck is going on? Anything I should do while the head is off? should the head/block be shaved or something? Could the piston rings be replaced with std. bore rings, and leave the block in the car. I need answers fast. Its been at his shop for a month and our paitence is wearing thin. Thanks.
