4g63t
- 1,568
- 13
- Aug 14, 2005
North Iowa,
Iowa
Alright im going to try to explane this the best I can. I have a 93 tsi. I just put a 2g manifold on my car because my tubular one cracked. So I took off my turbo and put the different manifold on, put it back to gether and drove it. About 10 min later my car started to smoke like a Bit@h. I am going to upload a video as soon as I can. My turbo is not blown because there is no oil in my intake pipes it is all dry. The only thing I have questions about with the turbo its a gerrett core so the bolts going to the exhaust side and around them seem to be oily is there some sealent or some way to torq them down. Is there a special way so oil dosent come out? Here are some picturs to help explane what I mean. Sorry for the quality.
http://s137.photobucket.com/albums/q218/lelej1080/?action=view¤t=000_3876.jpg
These are from close to under the tubo.
http://s137.photobucket.com/albums/q218/lelej1080/?action=view¤t=000_3875.jpg
http://s137.photobucket.com/albums/q218/lelej1080/?action=view¤t=000_3874.jpg
I was thinking it is eather the oil on the turbo geting into the exhaust side of the turbo and making it smoke or my rings/valve seals/ hg is shot. I built my engine about 3000 miles ago and it still runs vary vary strong. I just did a compression test and I got 130 140 130 140.... I thaught it should be higher because I just rebuilt it. Please I need all the help I can get so I cant get this smoke machine running good and to the track. I will check this often and try my best to help awnser your questions. THANK YOU
