CPHunter
- 1,005
- 2
- Aug 3, 2004
Winnetka,
California
Ok so i did my motor build. i started it up last Thursday and this past thursday it died
.i did all the checks then i said i'll look at the timing.So i have a question. when my crank is alined with the timing mark my stock cams and gears are both advance 3 degrees in timing. how bad is this. did i bent valves again? or can i just put it back on time and it will run. i notice that everything was tight til i got to the tensioner on the intake side. so if anybody can answer my question thanks alot.
I did the timing before i put the motor in the car. a must have spun the thing like a million times making sure everything was tight and making sure it wouldn't jump. so i am really confused
.i did all the checks then i said i'll look at the timing.So i have a question. when my crank is alined with the timing mark my stock cams and gears are both advance 3 degrees in timing. how bad is this. did i bent valves again? or can i just put it back on time and it will run. i notice that everything was tight til i got to the tensioner on the intake side. so if anybody can answer my question thanks alot.I did the timing before i put the motor in the car. a must have spun the thing like a million times making sure everything was tight and making sure it wouldn't jump. so i am really confused
