STARION
- 193
- May 30, 2002
Nova,
Now, being as how us DSMers are so lucky to have factory turbocharged cars.....we aren't really concerned with turbocharging other cars. However, there isn't really that much to it is there? I am looking to create a basic guideline of how to turbocharge any car.
first: decide on the type of setup, decide if single, or twin turbo is practical for the application and don't kid yourself on the practicality of the setup you choose. Get the "bigger is better" mentality out of your head. Keep in mind the displacement of the motor, drivability, etc.... in relation to the size of the turbo.
second: computer limitations: Here is where my questions begin. Now, our MAS is located before the compressor inlet, I would guess that any car with a mas, when turbocharged, should have the air metered before entering the compressor. Out of curiousity, what would happen if the MAS was repositioned and was actually relocated within the intake tract and was metering the compressed air? The volume of air is still the same, is it not? Or can the MAS not recognize the pressure and have you running lean on boost? However, cars with a map are lucky and have no worries when it comes to air metering under boost, is this correct?
third: You would design the manifold for the bolt pattern, port size, turbine housing bolt pattern, the amount of room you have available, and have one custom made, make one, or buy one (if it exists for your application). The material and its thickness is very important when it comes to choosing a turbo manifold.
fourth: Boost:Ensure that there will be enough fuel for the amount of boost you are running (upgrade pump, injectors, fine tuning devices, etc)
Also relating to boost, is the compression of the motor..... Decide if compression will be lowered to handle more boost.....buy or have forged pistons made to lower the compression, consider a metal head gasket, head studs, etc.. If you're going nuts and are rich, maybe you might as well build the whole motor since the head is already off
fifth: Putting it all together: bolting on the turbo/wastegate/manifold. Then choosing the sources for the water and oil lines. I would think you want your water source as close to the water pump as possible, then find a water return line. I think a good place for this would be on the thermostat housing, maybe? Then oil lines: I think the easiest thing to do for an oil source is to find a filter sandwich adaptor with 2 ports, make sure you know which is return and recieve and run these to the corresponding ports on the turbo. Although, I may be wrong here and am not certain if the pressure of the oil entering the filter is necessarily high enough to feed the turbo?(an oil cooler is probably a good idea, along with an upgraded radiator)
sixth: Intercooler & piping to TB, BOV/ compressor bypass, necessary heat shielding, etc....
I have a question here....Carbuerators: what happens if you run a turbo sytem on a carb'd car. Can you run the intercooler piping over a carb just like a TB, or what (of course you would have to rig up something that would fit over the carb and seal up right)? Do carb'd cars just hate turbos or what?
oh yeah, and fab up an exhaust.
This is just a very basic outline and some of it is overkill, but I think everyone knows what I'm talking about here. This is mostly about the
custom turbo setup that you make with an old 14B or something, when you're bored and have some spare time. You know, you decide to make a turbo system for your old corolla (or whatever), and you do some fab work and spend 200 bux and have a simple system thats good for 5psi........Thats what this is really meant to be about.
after all, Boost is good
.fifth: Putting it all together: bolting on the turbo/wastegate/manifold. Then choosing the sources for the water and oil lines. I would think you want your water source as close to the water pump as possible, then find a water return line. I think a good place for this would be on the thermostat housing, maybe? Then oil lines: I think the easiest thing to do for an oil source is to find a filter sandwich adaptor with 2 ports, make sure you know which is return and recieve and run these to the corresponding ports on the turbo. Although, I may be wrong here and am not certain if the pressure of the oil entering the filter is necessarily high enough to feed the turbo?(an oil cooler is probably a good idea, along with an upgraded radiator)
