jaden
- 85
- Dec 21, 2008
st.marys,
ON, Canada
Check out my add on kijiji.
Talon Eclipse laser DSM 4G63 TSI AWD PART OUT - London Engine, Engine Parts For Sale - Kijiji London Canada.
Not interested in shipping anything. Pickup only please
This is now a full partout and parts are going fast dont wait or you will miss the parts you need!
This car was going to go on the street I drove it with a 10 day pass untill it ran out and had an engine failure near the last day. all parts that I have marked (new) were put on and only driven for these 10 days. EVERY part that is listed here is in excellent condition. there is no junk here. most items that are listed are in like new condition.
the transmission can be seen here
Jacks Transmissions LLC — Stage 2.1 Ultimate Synchro
PARTS ARE: JACKS STAGE 2.1 TRANSMISSION WITH 4 SPIDER CENTER DIFFERENTIAL $2000 (NEW) SEE ABOVE FOR MORE INFO
GOODYEAR EAGLE GT TIRES 245/45/17 WITH EVO 8 WHEELS IN GOOD CONDITION $1200 (NEW) -SOLD
MASSIVE KINETIC FMIC INTERCOOLER WITH 304 STAINLESS PIPES AND CUSTOM BUILT J-PIPE, SILICONE COUPLERS AND CLAMPS $500
EVO III 16G TURBO FULLY PORTED (PROFESSIONALLY)
IN GOOD SHAPE NO PLAY IN SHAFT $250
TURBOSMART ULTRAGATE 38MM WASTEGATE $150
HKS 280 CAMS $350
CUSTOM BUILT 304 STAINLESS TUBULAR MANIFOLD WITH HEAT WRAP $350
304 STAINLESS INTAKE PIPE WITH K&N FILTER, SILICONE CUPLERS AND CLAMPS $100
PTE 1000CC INJECTORS $200
13 COBRA BRAKES WITH VR4 4 PISTON CALIPERS FRONT WITH HUBCENTRIC RINGS $550 (NEW)
KYB AGX SHOCKS WITH TEIN LOWERING SPRINGS $300
PTT TWIN DISC CLUTCH WITH SPECIALTY THROW OUT BEARING $750 (NEW)
AEM EMS COMPUTER WITH MAP SENSOR $700
AEM WIDEBAND $100- PENDING SALE
3 EXHAUST WITH DOWNPIPE 409 STAINLESS $300
4 BOLT REAR DIFF WITH AXLS AND CUPS $350
TRANSFER CASE $80
MITSUBISHI SHIFT CABLES BRAND (NEW) $80
MITSUBISHI MASTER CYLINDER (NEW) $60
MITSUBISHI SLAVE CYLINDER (NEW) $30
STAGING BRAKE $200
TURBOSMART DUAL PORT BLOW OFF VALVE $150
AEROMOTIVE FUEL PRESSURE REGULATOR $100
FULLY POLISHED VALVE COVER WITH ADDED VENTS $40
CUSTOM MADE 1/8" ALUMINUM DOOR PANELS WITH WINDOW SWITCHES $80 (NEW)
POLY ENGINE MOUNTS $40
WALBRO 255LPH FUEL PUMP $40
AC DELCO BATTERY (NEW) $60
SPARCO HOOD PINS BEST OFFER
ORANGE SHELL WITH 8 POINT ROLL CAGE AND LEFT OVER PARTS BEST OFFER PAINT WAS DONE BY BLACKTOP CUSTOMS NOT LONG AGO.
ALL PRICES ARE FIRM! PARTS ARE IN AMAISING CONDITION AND LISTED FOR LESS THEN HALF THE PRICE OF WHAT THEY ARE NEW.
Talon, laser, eclipse, TSI, AWD, DSM, Turbo, GSX, GST, 4G63
Thanks
HKS 280 CAMS $350
TRANSFER CASE $80
STAGING BRAKE $200
Thanks
