I need help crankshaft senor problems
lassssten
May 23, 2012
sarnia, ON, Canada
HI every im from sarnia ont little town outside london ont I have a 1990 eagle talon tsi front wheel drive I just replace the crank shaft sensor an the motor still wont start there for im thinking the timeing is off if an one has any helpful info please post or inbox me
Okay. I would still check your timing if you want.
But your no start, is the starter rotating or is it just dead?
If it's rotating, you need 4 things to start an engine.
Fuel
Air
Spark
Compression
If it is not engaging, check battery voltage, fuses and relays.
Another test, is to jump the starter solenoid terminals to see if it engages.
If that works, you can test the starter similarly.
Make sure you are in neutral and have the brake on.
Need more info to help you though. ;) it doesn't start and it still doesn't start are a little on the vague side. ;)
Good luck.
Thank you that waas useful an yes my timming was by alot im thinkimg of putting a bigger turbo any sugestions ?
Not quite sure of what you are trying to say about your timing there.
I looked at your profile and with the fact that you have nothing listed on it, all I can assume is that you have a 90 talon tsi, that is completely stock.
You may already have the 14b turbo on there, not sure.
I would need more info to help you with suggestions but for sake of ease.
16g or bigt28, 650cc injectors, walbro fuel pump with rewire, afpr, wideband, dsmlink, etc.
It's really hard to figure out what you need with little input.
Your best bet is to figure out your budget and what hp number you would like to hit and see if those two numbers work together.
I can help along the way but only so far... ;)
I used to live in London as well. ;)
