trig21turbo
- 30
- Dec 7, 2003
Marietta,
Georgia
I am tryin to position my cams at TDC, and the crank at TDC, We forgot to mark them when remoing the timing belt, now both cam markings are at 12, and the crank mark is almost at 4, Would the crank at 4 allow me to turn the cam sprockets to get them at 3 and 9 without bending valves, then allow me to turn the crank to TDC set the rear balance shaft and then replace my timing belt?
Thnk you
Thnk you
