laser92awd
- 128
- Jul 13, 2002
Central Florida,
Florida
I am interested in talking to anybody who is running (or has run) a B&M CommandFlo fuel pressure regulator. I just put my car back together after putting on an extrude honed intake, 550cc injectors, VPC Prom, and B&M FPR.
About the only leak I found when doing an air pressure test was around the screw on the B&M. I would like to know if this is normal or not.
Next, when I first started the engine with all my VPC and GCC settings at default (12 o'clock or "0") the engine was running VERY rough. So I looked at the fuel pressure with the vacuum hose off the regulator and was running around 50psi. I tried backing the screw out on the B&M but I couldn't get it to lower the pressure. The screw is almost all the way out (cam cover wouldn't even fit) and it still doesn't seem to have any control.
Deciding it was running rich due to the high fuel pressure I cranked my VPC gain and idle controls to full minimum, then leaned out the 500 and 2500 rpm settings on the GCC. It is idling pretty decent now but I'm concerned about now being able to lower the pressure.
I know some of you don't like the B&M and it may turn out I wind up going back with a stock regulator. But I'd like to talk to anybody who has experience with one.
Thanks!
Jonathan Stanley
1G AWD 16G Laser
Thanks!
Jonathan Stanley
1G AWD 16G Laser
