anomalyinva
- 211
- Aug 12, 2003
This post is to try and cut out some of those "what do I need to run x hp", though I doubt it will work. As well, it will deal strictly with 6-bolt motors as I really have no specific knowledge of 7-bolt motors. People have run deep in to the 10's on the stock long block (bottom end/head), are you going to go faster than that?
First off, what are your goals?
300whp - You do NOT need anything for this really as far as the motor goes. I would suggest going with the following though:
New OEM Mitsu Headgasket, new timing belt/tensioner, balance shaft eliminator, and ARP Head Studs
400whp - You don't NEED a built motor for this, though this is the range where I think it would be wise. I suggest the following:
EITHER Ross 8.5:1 pistons on 1g big rods, OR Ross 8.5:1 pistons on Eagle H-Beam rods. As far as head work a simple port and polish, and a 3 angle valve job will probibly help a bit
450whp - If you're running this any kind of consistently on the stock motor and not blowing it up, please come tune my car. Refer above for work
500whp - I seriously doubt you are reading this post if you are capable of building a 500whp 6-bolt. For the sake of the post though, I would go 1mm oversized SS valves, a fairly agressive port n polish, Cometic HG or Mitsu MLRS, and fully balanced and weight matched internals.
This is by no means to an end. This is just what I would do if I was building a 2.0 6-bolt motor. There are a LOT of issues that aren't discussed here. What are you using to tune? What is your fuel system like? Why in gods name do you think a 3 bolt will hold 450whp? ETC. This is just ment to be a starting place for those semi-new to DSM's.
